Sandisk s 200GB MicroSD Card Will Turn Android Phones Into Portable Hard Drives
G+_john ferris
Yes.  You know like those external wifi hard drives they have?  Instead of spending $50 for that and having my G3, it would be good if I had an app that let the iPad connect to the G3 as a tether (wifi) and could see that as some kind of web interface like you can with the Seagate Satellite drive, for example.
