G+_LostInTechnology Posted April 25, 2014 Share Posted April 25, 2014 [How To] – Calibrate An Android Phone’s Battery Every #android OS has a default battery app, which displays all the necessary #phonebattery statistics for your phone. The #app is quite informative as it shows things like the exact battery percentage, the time running prior to battery charge, and a break-down of the various apps using up your battery resource. In some cases, when your battery is not calibrated, this app might give errors in the statistics or show nothing at all. Calibrating your battery can fix this issue, and hopefully improve your performance along with it as well: http://www.lostintechnology.com/how-to/calibrate-android-phones-battery/ #batterylife #battery #batteryissues #androidbatterylife #androidbattery Link to comment Share on other sites More sharing options...
G+_Brandon K. Posted April 25, 2014 Share Posted April 25, 2014 Hasn't this been proven false? Link to comment Share on other sites More sharing options...
G+_Mark Stronge Posted April 25, 2014 Share Posted April 25, 2014 Brandon Kapp yes, you can delete battery stats by charging fully and then unplugging your phone, it does the same thing. Link to comment Share on other sites More sharing options...
